TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Assuming the injectors are good, I think "O" ring.
Subject Re: Re: Re: Re: Assuming the injectors are good, I think "O" ring.
Posted by msb1987 on January 22, 2015 at 9:40 PM
  This message has been viewed 199 times.
In Reply To Re: Re: Re: Assuming the injectors are good, I think "O" ring. posted by jmay on January 22, 2015 at 09:43 AM
Message The injector can be fine but the o-ring could be the problem. Run it for a bit and then pull the plugs on those cylinders to see if they are wet. If so then test for spark. Where you go from there depends on what you find.
